26-06-2021, 09:02 AM
(26-06-2021, 08:51 AM)boater sam Wrote:(26-06-2021, 08:45 AM)Murphyv310 Wrote: Oh no.Well Trevor, you have almost exclusive use of the EF80 apart from early VHF tuner heads. You can't have it all your own way!
Another rare TV valve
What with audiophools now its DAC90Aphools
Hi Sam.
I'd happily give you a load of EF80s there must be millions still around. The issue is using specific TV valves in radios. Substituting an audio output valve into a frame or video amp section in some of the Ekco and Murphy TVs with 100ma heaters is difficult and causes picture issues. The UL84 is the official mod for a UL41 the UL44 & 46 are rare and so are the sets Tey we're used in, I have one UL44 and no 46s so I'd rather keep it for a TV Collector, I've used a 10P13 before but even these are hard to find now.
Cheers.
Trevor
MM0KJJ. Member of, RSGB, GQRP, WACRAL, K&LARC.
Trevor
