23-06-2021, 08:30 PM
Hi Bob, still worth doing the pin 4 mod as it is not known what might be fitted in the future
Ed
Ed
Bush DAC90A Chassis
Ed
24-06-2021, 05:56 PM
(23-06-2021, 08:30 PM)Ed_Dinning Wrote: Hi Bob, still worth doing the pin 4 mod as it is not known what might be fitted in the futureSaid that way back....................................................................
Boater Sam.
25-06-2021, 12:58 AM
boater sam Wrote:Ed_Dinning Wrote:Hi Bob, still worth doing the pin 4 mod as it is not known what might be fitted in the futureSaid that way back.................................................................... Cloying, isn't it I wonder how many otherwise good, sooty valves have been thrown out.
25-06-2021, 08:29 PM
Hi Ed & every one thanks for advise keeping this one as standard as it is not getting used much been slightly OT my main set is a white DAC90A i fitted Ed Dinning auto transformer did my modification fitting a UL44 valve and this set runs very cool nice bright dial lamps but not over the top and it sound great and is very reliable kind regards Bob
26-06-2021, 07:49 AM
(This post was last modified: 26-06-2021, 07:51 AM by Murphyv310.)
(25-06-2021, 12:58 AM)Amie Wrote:boater sam Wrote:Ed_Dinning Wrote:Hi Bob, still worth doing the pin 4 mod as it is not known what might be fitted in the futureSaid that way back.................................................................... The thing is they still leak. Even lifting pin 4 isn't a total cure. I've seen many with positive grid 1 volts upsetting the bias. 10P13s are hard to find as it is and when used as a frame output there is no direct equivalent for vintage TVs a UL41 or 44 will work but linearity often cannot be corrected, so it's now a shift from those that collect DAC90As and us with 405 Line TVs. My personal belief is to fit a UL84 and rebase the holder, these are very reliable valves and in more plentiful supply. We don't want the radio collectors pinching our TV valves
Cheers.
Trevor MM0KJJ. Member of, RSGB, GQRP, WACRAL, K&LARC.
26-06-2021, 08:43 AM
I have gone over to UL46 as a sub. Easy to arrange the top cap connection.
Boater Sam.
26-06-2021, 08:45 AM
(This post was last modified: 26-06-2021, 08:47 AM by Murphyv310.)
Oh no.
Another rare TV valve What with audiophools now its DAC90Aphools
Cheers.
26-06-2021, 08:51 AM
(26-06-2021, 08:45 AM)Murphyv310 Wrote: Oh no.Well Trevor, you have almost exclusive use of the EF80 apart from early VHF tuner heads. You can't have it all your own way!
Boater Sam.
26-06-2021, 08:54 AM
A UL84 conversion is the recommended replacement for a UL41 in my 1970 Mazda data book, with a bigger cathode resistor.
Cheers.
Trevor MM0KJJ. Member of, RSGB, GQRP, WACRAL, K&LARC. |
Users browsing this thread: |
1 Guest(s) |
