13-02-2020, 09:56 PM
I dug this little active speaker out from on top of a cupboard where it has been resting for 20+ years, to use it with a morse practice oscillator. It is left over from my 16mm film days and I think that it came with an Acmade picsync used for synchronising the sounds on 16mm magnetic tapes with the 16mm film print. I gave the picsync away a long time ago but for some reason held on to this. It uses a single PCL82 but there is a transistor lurking under the chassis.
I reformed the smoothing caps and did a visual then checked a few resistances and some capacitors for open circuit, plugged it in and it still works! It isn't HiFi but it will do for what I need. I am not sure that this is the correct place for this post but the picsync is in effect a tape player.
