01-08-2020, 07:37 PM
(This post was last modified: 01-08-2020, 07:38 PM by Mike Watterson.)
Arrgh. Horrible.
Three attempts to get the tuner fixed.
It's not easily taken apart as there is a soldered on spring rod to earth the rotor at the front, so I didn't. Soldering the spring back in under tension is probably even harder.
There is a long boring story, but eventually it checked out on the continuity tester. However you could hear it shorting. So off with the connections to RF and LO coils. Put 32V current limited to 2A and see where it sparks! Sand and prod plates till it's OK.
Now stick in chassis after sanding end of shaft and reaming the knob a little so it doesn't need a hydraulic press for reassembly.
Re-align 1500 kHz and 600 kHz (trimmers UNDERNEATH tuning cap accessible via holes in the chassis. The isolation transformer is great. The LO coil is behind the 1R5/DK91 so if you have a not too tall and not too short trimmer you can access it from the top. Also accessible from underneath, but even then my plastic trimmer is too long. An old Philips' one with a brass tip and various lengths of handle fits.
Re-align 1500 kHz RF trimmer. The BBC R4 LW is maybe a little weaker, but tracking is now much improved with RTE1 LW very strong. MW seems sensitive based on signal generator level, but doesn't pick up Spirit from North Cavan. Amazingly the Decca TP60 with the GEC transistors does.
Date stamp on the back cover is 25th February 1958. I suppose opting for the louder 3V4/DL94 rather than the DL96 meant all 50 mA types, was a 1R5 so much cheaper than a DK92 in 1958, though no SW anyway. A badly laid out version of a 1946 radio with horrible access and even for 1950s a poor design from a safety point of view?
Just needs cleaned a bit now and see what it's like from dusk on MW.
I thought maybe it might need half a dozen capacitors changed and it would be a simple one. Maybe I've used up all the simple ones.
