Warning, Danger, Will Robinson!
The chassis is potentially live with no interlock. Not a big issue on a mains only radio, but this also takes batteries.
NINE useless resistors packaged as paper dielectric capacitors, AKA Waxies. But not all paper dielectric capacitors are in waxed card tubes. Some are in metal cans with rubber bungs. Some use a plastic that goes brittle with age (Hunts Modseal). Some military ones and some used in EMI sets are well enough sealed that they might be OK. The so called Paper In Oil, may just the same thing with a better sealant. The paper is impregnated with a kind of paraffin, but paraffin does eventually allow water to dissolve in it. The really good PIO use hermetic seals and a more expensive oil more resistant to water.
This set had nine. One across the mains. Two on screen grids, one on HT, mysteriously a 100nF (0.1uF) in series to switch to switch in the LW Local Oscillator (LO) capacitor. I suspect a piece of wire works there.
1S5/DAF91 anode to 3V4/DL92 grid, 1S5/DAF91 grid, AGC time constant, 'tone correction' (snubber) on T4 primary output transformer.
The 1R5/DK91 filament was open circuit. I first checked LT from bench PSU at 7V. About 6.5V to 7V is right for mains or external PSU. The 7.5V is a nominal FRESH battery, and the set should work somewhat at about 5.5V or a little less. The LO stops first. I used an external 90V HT PSU also.
I could see leakage of LO on the scope on volume control, so it was tuning and also waveband changing.
Two turns of wire on ferrite rod and 470K, close tuner and select MW. The four IFT coils spot on.
About 600 KHz and 1.5MHz also worked on signal generator.
Tried LW with 250 KHz. Where are the pesky trimmers?
The MW RF & LO for 1500 kHz peak are on the main capacitor, but under the chassis, so you kill yourself if it's not an isolated supply. Really awkward. No LO trimmer for LW (not extraordinary, hence suggestion to adjust 500m/600kHz LO coil before LW. LW RF trimmer is just under the back of the wave change. Tweaking it (it was fully tightened!) brought up the signal massively. So much so that RTE1 LW was breaking through. Disconnect SG and peaked up RTE. Only a faint fistle at R4LW.
So fitted it all in the cabinet and put a 5 amp three pin plug on. My boxed shaver adaptors have a hole drilled for the 3rd earth pin. I considered putting a polarised flex, but left the anoymous two core on it. I'll add a warning label on chassis, cable and plug.
Next time I'll align MW properly now it's in the cabinet and I can see the scale. Then redo LW.
Finally I'll test Franken Mixer/Oscillator with a ballast added so it's 50 mA series. The 1R5/DK91 has no screen grid supply like the DK92, 1L6 or DK96, but my Triode-Pentode oscillator/mixer doesn't use it. So it should "go" in the DK91/1R5 socket.
Note that the Trader Sheet 1331 14th December 1957 and the R&TVS 1958-59 volume page 212 use different component numbering.
IF amp is a 1T4/DF91.
I should check what voltage & type the 1nF to the aerial socket is, as the other end of it goes to the chassis via a tap on the MW coil. It's not shown on the Trader circuit.
The Selenium rectifier appeared to be open circuit, so I soldered a 1N4007 direct from mains in wire to the 32uF smoothing cap (C26 Trader, C23 R&TVS). I've 230V here (because that's the Irish harmonised 220V) so I'll check HT caps with 30V PSU first and then try on the 250V tap. It's possible no extra series resistance is needed.
There is what might be an asbestos disc on the end of the dropper. Such things are best left alone or soaked in repair cement or similar to stabilise fibres. The DAC90 (not a DAC90a) has rather more asbestos. It will get the cement treatment.
The later Vidor mains/battery sets with a potentially live chassis (some had isolated PSUs) had a cunning arrangement of an ordinary in line cable two pole plug and socket that unplugged when the back was opened.
