30-04-2019, 09:54 PM
Hi Jac
All my Hedghogs don't have that problem.
Only once have I ever seen anything like that and in that case I traced it to a faulty modulator chip. But it did look different to what is displayed in your photo. It looked more like ignition noise.
Have you try a different power supply?
If you have a separate System A modulator you could take a look at the video coming out of the Video out socket. That would tell you if the problem is in the modulator or before it.
If it is heat sensitive you could try tracking it down with a hairdryer and freezer spray.
Frank
Frank
