19-03-2019, 08:48 AM
Thanks for reading my posts on diyaudio.com. and clarifying the difference between Iq and DC offset, mark, though I did know that, in the case of the A3i and other amps. with emitter resistors, the Iq can be easily calculated by ohms law once the voltage drop across the emitter resistors has been measured, and in one of my posts about the A3i, I did note that I had confused the DC offset (which, of course is measured across the speaker terminals, or, as in most cases the speaker neg. is grounded, between the positive speaker terminal and earth)., and should ideally be zero. Should know better than to mix the two parameters up after almost 50 years!!
