13-12-2018, 03:10 PM
Surely if you drive the non grounded grid of the LTP with enough audio at some point it will over drive into distortion far enough for the cathode to go above ground so that the other cathode being linked to it will follow.
The one with the grounded grid will be cut off so that only the input one takes all the current.
The CCS will need a voltage rating to cover for this otherwise you will for ever be replacing components.
