28-09-2017, 04:46 PM
Adaptive interpolation can work, it's complicated to get it to work well. Just look at the de-interlacing on many flat panel TVs; it can be really horrible on things that are moving. Just watch something that's slowly moving and then stops. And snaps into focus. Better sets do a respectable job but they are stuck with the facts:
1: Most motion is already aliased (inherently by the field rate, akin to wagon wheels going backwards in cowboy movies) which makes 2: even harder
2: On an interlaced image motion and vertical detail can occupy exactly the same 2 dimensional frequencies and hence impossible to separate reliably
It can be done very well indeed, some modern TV chipsets are excellent but they can be caught out on occasion.
Add all the data rate compression used for recording and transmission, which is taking liberties with motion anyway, and you can end up with revolting pictures on occasion. On the whole it works OK provided the broadcasters and mastering engineers don't push the compression too hard.
If you yearn for analogue PAL, just remember the cross-colour effects on fine luminance detail. They weren't very nice either though comb filter decoders could minimise the problem.
