30-03-2017, 03:22 PM
Depends how big it is, but if you could make the top panel from aluminium, you might not need the fan. You could bolt everything to it, including a bridge rectifier and the transformer, and the heat is conducted straight outside. Would be a neat construction...
Just make sure it (or any other metal like your grille) is firmly connected to mains earth. If there's space, a fused IEC inlet is recommended.
