18-03-2017, 12:43 PM
I’ve acquired a few Atwater Kent sets and the battery models need 6 volts on the HT. They use mainly 01A valves and draw a lot of current. I tried a 6 volt battery but that dropped to 4 volts when I turned the sets on.
I think I better build a meaty HT supply, and I found a beefy looking toroidal transformer that has no colour codes written on it for the two sets of secondary’s and does not tell me what sort of power it gives out. It’s an Antrim make and the 2 secondary’s are blue, red, yellow and grey – I joined up the blue with the red and then the yellow with the grey so they should be in parallel
I weighed it and it is just under half a kilo, then connected it up and the two sets of secondary windings gave 6.7 volts each. When I joined the 2 secondary’s up it still gave 6.7 volts so should be man enough for the job?
I’ve got kbpc104 bridge rectifier (good for 3 amps) and an LM338T regulator (good for 5 amps) and a 470uf.
I had a thought though – if just one secondary could put out 6 volts 2 amps then I could wire the other up and drop the voltage for my 2 volt sets.
Apart from looking up other transformers VA rating and their weight then taking a rough guess is there anyone who knows the rating for the Antrim transformers type B2010 YK08, or another way of finding out the VA rating?
