10-04-2015, 03:26 PM
(This post was last modified: 10-04-2015, 03:30 PM by Nowhere-Man.)
(09-04-2015, 08:56 PM)Refugee Wrote: The yellow cans will be OC81D and two OC81 transistors with sleeves over them like the red ones on the AF117s.
What is the component that is slightly obscured by the aerial between the coil connections? If this is a capacitor replace it before you do any other work as it is likely to be the power decoupling capacitor for the audio driver (OC81D) and will be causing the oscillation and overheating.
The method I use to deal with AF117s is to disconnect the screen lead by heating the solder and lifting the wire and cleaning the solder off the board so that there is no connection and then measure it again. Your meter will be reading the biasing resistors if the screen is connected to the earth track.
If there is now a reading when the isolated screen is measured it can be treated using a 12 volt power supply and a 100 ohm resistor and three silicone rectifier diodes.
First connect the diodes in series and connect the banded ends the same way round with the end one connected to the negative of the power supply and the resistor to the other end and connect it to the positive side of the power supply. You can if you want monitor the junction between the diodes and the resistor with a moving coil meter.
Now connect the junction between the diodes and the resistor to the screen and touch the negative of the meter and the banded end of the diodes to the electrode with the lowest reading when you tested with the meter. If you have the moving coil meter connected you should see a very short dip in the reading from a little under 2 volts for a fraction of a second. You should now find that the fault is gone.
In the data sheet for the AF117 the maximum applied voltage between any two pins is about 3 volts or so so the silicone diode shunt regulator is enough for you not to need to take the transistor out of the board.
O.K., I took your advice and removed the collector and screen pins from the PCB. I tested between the two leads and got an infinity reading whereas before I was getting an Ohms reading. So, your advice was spot on. I didn't test the other transistors so far. Thanks for that tip.
The capacitor by the ferrite coil I was asked about is a 6 volt cap but I'm not sure I could get it out without removing the dreaded string winding mechanism on the tuner to get access. I live in hope I don't have to later on face the prolonged task of another fiddly stringing.
Here is some very good news: I now have a very healthy audio output stage. There is a healthy hiss and a slight change on hiss when the waveband frequency change knob is used. Above all, on inserting a screwdriver on the end of the central volume pot terminal there is a very definite hum. Also, the same switch last night was doing nothing but now it works and you can switch the radio off with it.
I'll explain:
I realised today that what was really adding to a lot of confusion was the earphone jack plug. I'd been extra careful to get the pot terminals correctly wired but many wires run to and from the earphone jack and I think possibly a wire must have worked loose when I was soldering. I was starting to have major doubts about the wiring in that area so I decided to do away with the jack totally for now and simplify the whole thing. I then just wired from the transformer as you would normally do on a valve radio. I did actually take pics of the ear-jack at the beginning but found it was a bit jumbled. So, now I appear to have a healthy and hopefully undamaged audio output stage.
The problem now remains is how to inject the demodulated I.F. into my audio. Well, it could be a transistor but there are two important points I need to clarify: First of all, the central lug on the volume pot isn't connected to anything at this point. This is hard to explain but it did lead to the ear-jack. There is one snapped grey wire soldered on the PCB right at the edge (it had just snapped while I was soldering but I didn't notice at the time). Also a lower speaker wire had snapped off the PCB as well, near to the waveband change knob. So, there are 3 disconnected wires and it may well be the case one of these could get my reception back.
Lesson learned? Wires have a habit of snapping off while you're busy working.
