16-03-2014, 05:08 PM
(This post was last modified: 16-03-2014, 05:24 PM by Radio Fixer.)
Well I cant let David have all the limelight with his AC77.
The wiring on this beautiful radio was mainly shot. Touch much of it and it simply crumbled away so it was strip and re-wire. I did detailed layout diagrams, and the A3 printer was essential for clarity (photos on their own are not good enough).
It is 1934 and an export set so has LW and is 230V. Over here it would have been a 2 chassis job but the US never did table radios that way as far as I know. 8 tubes, tuned RF, 2 IF stages and PP so it will perform well I'm sure. SW's go up to about 22Mhz.
Wax Caps are not re-stuff as the cases fell apart but are dummied from styrene tube. Many were good for leakage but some were O/C which is unusual.
Soon ready to tube up and test and then put back the rubber tyre tuning cap drive and the waveband scales which are mechanically moved up and down to the slot in the cabinet bezel.
The cabinet was refinished last summer, not completely but wounds in the black trim filled and re-sprayed, also a couple of holes in the LH side filled and then the whole cleaned, sanded with oh so fine paper and shot with a few coats of satin lacquer.
The first chassis pic was as it came to me ...trust mine looks better. Took me quite a while but at least there was no rust to deal with as David had. The chassis is nickel plated and the coil cans look as if they are from nickel sheet but with un-corroded ali. tops.
Be a BVWS Bulletin article later in the year and hopefully a front cover picture, if the Editor agrees its worthy, it certainly is to me
Gary
Gary
