02-02-2014, 01:56 PM
Our younger son brought a little 2-vale (or should I say 'tube'?) pre-amp to show me this weekend, which he's just bought on e-bay. It uses 2 x 6N11 (12AU7) noval twin triodes. Built on a good quality PTH PCB, with a Perspex top so you can see the 'innards'. The power supply is 18V AC input, and it came with an 18V transformer (220V input), and a rather messy multiple adaptor to adapt it to 13A UK plug. He asked if I could neaten that up for him, so I mounted it in a Maplin plug-top 'wallwart' enclosure. Not sure about the longevity of using a 220V rated tranny on 240V but it didn't seem to get hot in use.
He suspected that one channel might not be working as the output was low. I squirted a 20kHz sine wave into it, and true enough, that channel wasn't working. Checked the valve filament, which was fine - swapped the valves over, and yes, it's the valve that's duff - not one channel of the amp. Whether or not the supplier expects some valves to fail, I know not. Suffice to say that the amp came with a spare valve, so when our son gets home, he'll substitute the valve and hopefully, that will sort it.
Not expensive at 50$ US (£30 GBP) 'Buy It Now' with free post and it came in ten days.
http://www.ebay.com/itm/6J1-x2-HiFi-ster...0514046949?
6N11 valves are plentiful too, at about £6.00 each post free, both new Chinese and Russian old stock:
http://www.ebay.com/itm/NEW-Shuguang-Chi...0649841315 £6.00 each
http://www.ebay.com/itm/NEW-NOS-RUSSIAN-...0797482407
There seem to be lots of variants both one and 2 valve min amps, the one-valve ones being described as 'headphone amplifiers'.
There are tiny blue LEDs beneath the valves which light them up blue - gimmicky perhaps, or some might feel naff even, but hey - it looks quite cheerful!
I wound the sine wave generator up to 25 kHz and there was no sign of any distortion on the scope trace.
It remains to be seen whether it proves to be reliable in use - only time will tell.
The design needs to provide for the heaters and HT - anyone's guess how it does that, given the paucity of components!
The smallness of size can be seen when compared to the 'wall-wart'. (It's about 3" x 4" x 2" high).
Hope that's of interest.
