When I first started this I told the forum I was to embarrased to show pics of it....You can see why.
It is the Regenerodyne developement chassis, anyone recognize the donor chassis?
I had this chassis as a bare original hence everything is bolted on to existing holes where ever they may exist as the chassis is to good to drill.
The double tuned RF/Mixer stage can be seen where the twin gang job is, my homewound coils being in front of it, the VFO is on the right with the small control knob.
Valves left to right are RF amp, Mixer, Regen Detector, !st af (af o/p behind) and VFO osc.
The large upright coil is the homewound tunable regen det. coil.
The small upright panel has the regen det. tuning (large knob) and the bandspread/fine tune (small knob)
The two controls either end of the front chassis apron are volume (LH side) and Regen (RH side) the control on top of the chassis above the volume control is the RF gain pot. The small control which is outrigged on the RH side is the VFO tuning.
The large knob on the twin gang is the RF tune.
Anyone recognize the control knobs?
Bit of a mess but works very well.
