18-12-2023, 03:01 PM
Yes the main unit looks like the photos in the links, It has the Decca pickup fitted. Nearly all the caps have been changed before I got involved to new yellow poly ones. (part of the problem was some wiring errors made in the process) The screen resistors are a bit on the high side, there is no potential divider. I'll change the screen resistors and see what happens, and then re-check the others too at the same time. One of the valves wasn't even plugged in properly which didn't help! I've read people remove the spring clips - might be worthwhile insurance if I take a valve out.
Here is picture of the underside, not a pretty sight. David.
