17-12-2023, 07:33 PM
Greetings everyone,
I'm trying to repair a Decca VHF radio tuner. I've managed so far to make it tune in stations - a good step forward. But the AF signal level is very weak. I'm wondering what would be typical levels of signal through the signal chain. I imagine the AF output level should be a few hundred mV p-p ( I dont have this much yet). also what signal levels will be present through the IF amplifier and what gain will each valve provide. I have access to signal generator and HF 'scope to check but dont know what I'm looking for.
The tuner is of a quite simple design with double triode front end followed by two EF41 IF amplifiers and a EB91 double diode ratio detector, thats all. Power is fed in from the audio amplifier. probably something similar o the old Jason tuner. it didn't do much until I fed it with a strong signal from the external aerial, I was expecting to hear a hiss but there is hardly anything at the output. The scope show audio quite clearly though. My investigation has been hampered by my new (old) signal generator deciding to stop modulating which led me up the garden path for while.
Some schematics of similar devices show representative DC voltage levels but I have seen nothing with actual signal levels.
TIA for any information, David.
