15-12-2023, 12:25 PM
Curiously I used an Intel MDS with ISIS II and the "cake carrier" winchester drive like a small filing cabinet in 1983. We did most of the dev on an ACT Sirius 1 and I had a Jupiter Ace at home with a 1K pacman. We bought a Jupiter Ace in work as a controller for a test system. Forth was OK if you'd used an old HP calculator.
The next place had a VAX, Cromenco with 68000 & Z80 and Cromix, and Apricot PCs with the too small mono screens. We got one PC with colour SVGA or XGA for CAD/CAE running FutureNet the next year, IMO better than OrCAD or Eagle or KiCad, though DOS, because it was hierarchical with "hypertext" style links to expand a block symbol to a new drawing showing all the i/O to start with. I implemented a DFD programming language on it where the final "ICs" could be code. Then the parts list, net list and part descriptions exported and "compiled" for a custom round-robin multi-tasking system implemented on a Z80. The Alternate Register bank used for the scheduler code. The net-list was used to generate an I/O table for the OS where each routine got its inputs and saved its output. So actually the system could be modified today for a high end PIC as they really only have a stack for an interrupt, no procedure call stack.
I gave away an 8″ drive a few years ago. Anyone got a working 5.25″ 1.2M MS-DOS compatible drive (Likely soft sectored)? I set one up last week to see if some floppies have anything important, but though it spins, the LED doesn't light. I don't think it seeks either.
The Apple II floppies were very primitive.
I was also testing old 3.5" HD drives last week and junked 11 of them. USB floppy drives are no use for other than standard 3.25″ HD MS-DOS FAT12. I still have a few old mobos with floppy controller and port, though one seems to only support 1 drive in BIOS. You used to be able to connect four. Maybe no PCs with ISA, though I must check what the two slim desktops buried in shed are.
