(02-10-2016, 07:02 PM)ppppenguin Wrote: I think Cardigan is right here. If the cable isn't being used as a transmission line (more strictly if the transmission line effects are negligible) then capacitance is the dominant factor. It can be treated as a lumped capacitance and the effects of inductance will normally be negligible in such applications. This would cover audio for most distances and RF for short distances where the wavelength is much greater than the length of the cable.
I would point out that in the past I've seen a short (<50m) run of twisted pair driven from a 'balanced' source that was anything but - and of about 1000 Ohms output impedance - suffer from notable treble loss.
The driver was an op-amp with 1000 Ohms in series with its output in the hot side of the feed: the cold side was a 1000 Ohm resistor in series with a 100uF capacitor to earth.
