07-08-2017, 08:05 PM
Many pre-war Kolster-Brandes AC/DC mains radios employ the Brimar 10D1 or Mullard 2D13C double-diode as the detector and AVC rectifier. These valves are quite scarce so today I made up an adaptor so the more common 12H6 octal base double-diode can be employed as a replacement. The 12H6 has a 12.6volt 0.15amp heater so if the valve is to be used in 0.2amp heater chains a 250 ohm resistor has to be shunted across the heater pins 2 and 7. An old B5 valve base and an octal socket are used to make up the adaptor. A 2ohm resistor is connected in series with the 12H6 heater just in case I decide to use the valve in the MRG radiogram which employs 13 volt valves.
Geordie McBoyne.
Geordie McBoyne.
