15-12-2015, 10:54 AM
(14-12-2015, 05:32 PM)Nowhere-Man Wrote: ... I typed in 30 Picofarads and it was 0.00003 but the book has a zero less. Not that I try and catch these people out but I tend to automatically run any digit through my pocket calculator so I know where I'm at ...
(14-12-2015, 05:34 PM)ppppenguin Wrote: All these zeros confuse me too and it's far too easy to make an error. Anyone for 0.000000000003F? I really couldn't tell you without careful counting what that's meant to be ...
Small print on a printed page can be bad enough but on the screen is even worse! I think I have seen the use of spaces to break the series of zeroes into blocks of three - that, at least, would remove a lot of the confusion.
I prefer, though, to start from the smallest value and work up. Correctly done, this produces clear, unambiguous figures with no zeroes to the right of the decimal point and no more than two to the left.
Thus, using preferred values, picofarads are generally used for 1 - 820ρF then nanofarads for 1 - 820nF and microfarads for anything larger. I say generally because, whilst I would write, say, 4.7nF (or, for maximum clarity 4n7) others might prefer 4,700ρF - which is equally clear.
(14-12-2015, 05:34 PM)ppppenguin Wrote: ... I tend to use units that minimise the number of zeros though 100nF is a notable exception as 0.1uF has fewer zeros. Or scientific notation, usually with the exponent as a multiple of 3. If you're writing without superscripts then 30x10^-12F is easily seen as 30pF. Or as you'd enter it on many scientific calculators: 30E-12.
Surely it is easier to write the formula out first, translating pico, nano, micro, kilo and mega into the appropriate exponents as many of these will cancel out leaving a much simpler calculation before you even pick up a calculator?
