04-12-2015, 04:48 PM
I figured it might be a good reality trip to try and get my head around how the old radio engineers of the Thirties and Forties did their diagnostics. I chanced upon a book that was written in the hungry Thirties and then updated to 1943. It's less technical than my sixties Ham book but more practical from the actual engineering perspective.
Did you know, a lot of repairmen at that time relied on a Milliameter with a full-scale deflection of 0.005 Amp? Much of their work was done reading Milliamp deflections. According to the book, it was typical for the said Milliameter to have a resistance of 100 Ohms and deflection of the full 0.005 Amp at 5 volts. The book then launches into a method for testing voltages. Shunt resistors are wired in series with the circuit where the voltage might be expected to be, say, 50 volts. Then, it seems you would divide 50 by 5 to get 10, multiply the 100 Ohms of the Milliameter and then insert a shunt resistor of 900 Ohms. Presumably then if the device shows a deflection of the full 0.005 Amp. you can assume the circuit voltage will be 50 volts.
Then there is this device called a Galvanometer. This is used to read the Ohms of an unknown resistor. The said Galvanometer is connected to circuit with a large resistance cable shunted across the probes and fixed to a ruler. The centre probe is slid along the resistance wire till it reads 0 and that then is the point of the two resistances. If you know the resistance of the total resistance wire, you can then use the ruler to calculate the proportion.
Maybe it would be fun to rig this test up if I can find a Galvanometer online.
Might be worth while getting a copy of the Radio Engineers vest pocket book as well as that's said to be really good.
