I know that originally tuning cap bearings will have been lightly packed with grease, but I find that a needle point oiler with light oil does a good job at freeing up the bearings. Just a little spot of oil on the pulley pins helps reduce friction too. When tuning cords slip it's often a combination of things - a stiff tuning cap spindle, stretched dial scord and weakened springs. Maplin used to sell a needle point oiler with light PTFE loaded oil in them, but seem not to stock them any more. (No surprises there then).
There's a handy looking needle-point oiler from Amazon (cheaper than on e-bay for the same thing, with free P&P):
http://www.amazon.co.uk/Needle-Point-Oil...B001MJ0JTU
If you get a signal from the speaker when you inject a tone into the slider of the volume control Mark, that exonerates the detector, AVC and audio stage. If you then inject a signal into pin 1 of V2 and get a tone, that suggests that the 2nd IF amp stage is working. If you then apply the RF tracer probe to the same pin of V2, but don't hear any tunable signals, that points to a fault in the first IF, front end/mixer stages.
Hope that helps a bit.
I bought a manky spares or repair FB10 (for a tenner I think) at last year's NVCF as my son wanted a green one, so I restored it and airbrushed it green. I wrote a thread about it at the time but the pics have probably gone, so I've attached a couple of before and after pics. Not to everyone's taste I'm sure, but my son likes it. (I must get on and re-attach pics to old posts as they often make little sense without the pics).
Have fun!
David.
Have fun!
David.
BVWS Member.
G-QRP Club Member 1339.
BVWS Member.
