22-08-2023, 11:28 AM
(This post was last modified: 22-08-2023, 11:28 AM by ppppenguin.)
You've overthinking this. Just use a washer. Job done.
wanted
22-08-2023, 03:13 PM
(This post was last modified: 22-08-2023, 03:17 PM by Murphyv310.)
(22-08-2023, 11:23 AM)Fidelity 26 Wrote:(22-08-2023, 10:12 AM)Murphyv310 Wrote: All you need is a "P" clip. Just use a length of sufficiently wide cable tie cut the length you require. Form it round a bolt of the same or similar diameter as the ferrite rod, warm it a little so you can mold it into a P shape, once done either drill suitable holes or use a thin soldering iron tip. Plenty of ways to achieve the end result. In this hobby you have to improvise, so long as the rod is secure that's all you need to worry about. Using a washer is the simplest and easiest solution, I personally wouldn't get hot under the collar trying to get the exact part, IMO you won't!
22-08-2023, 04:47 PM
A bit of plastic tension strapping off a package, drill hole, wrap around, nut and bolt, job done.
Boater Sam.
| 2 Guest(s) |
