02-03-2016, 08:49 AM
(02-03-2016, 08:40 AM)Radio Fixer Wrote: I cant comment on whether you would need a grounded grid stage before each side of a valve long tail pair Jeffrey but it would be awkward to implement if the single turn loop were remote. Using transistors its easy to arrange to supply the 12V down the coax cable but for vales ... well HT and then heaters ...
Gary
Hi Gary.
Totally agree that power supply will be a bit of a pain. Grounded grid would be the way to go but I think output could be low unless the stage was followed by another stage.
A cascode amp actually may be the best solution with valves and even with the transistors used here.
