01-03-2016, 02:55 PM
(This post was last modified: 01-03-2016, 03:08 PM by Radio Fixer.)
There was thread some while ago but I thought it best to start anew.
Trevor sent me to a site that gave some theory (with maths which I still haven't got too far in following
) and then I got to this practical site: http://www.pa1m.nl/pa1m/simple-active-receive-loop/
Well, I have built the amplifier and made an aerial which is a single turn of 20 SWG wire and it works very well. It does the most, compared to a strung piece of wire, with sets that don't have an RF stage and not much gain but still is better with more upmarket sets. That's not giving it enough praise as it transforms an Ekco AC97 to closing the eye on so many MW stations
compared to 25 feet of wire strung around the room that doesn't close for any and only picks up a limited number.
Its for the Den and the idea is to mount the aerial as a square backing onto the centre double glazed window frame. It may have to be spaced off as someone mentioned that there could be metal inside the UPVC.
It will be right behind the work bench and so ideal for testing restored radios. At the moment the circuit board is on the bench connected by 4 ft of wire and so it might have less pickup when built as part of the loop. I have tested it with short output leads and 5 feet of coax to more distant receivers.
I also made a transformer (similar to Trevor's design) and it makes a small improvement on 'eye tube' closure but not huge. The idea was to match (somewhat !) the amplifier output (50 Ohms?) to the variable impedance of the radio.
The next step is to find / buy some 15mm copper tube and do a better job of mounting. I wonder how much difference it will make? The aerial output is proportional to wire area so it should.
Hope this is of interest and comments appreciated Gary
) and then I got to this practical site: http://www.pa1m.nl/pa1m/simple-active-receive-loop/Well, I have built the amplifier and made an aerial which is a single turn of 20 SWG wire and it works very well. It does the most, compared to a strung piece of wire, with sets that don't have an RF stage and not much gain but still is better with more upmarket sets. That's not giving it enough praise as it transforms an Ekco AC97 to closing the eye on so many MW stations
compared to 25 feet of wire strung around the room that doesn't close for any and only picks up a limited number.Its for the Den and the idea is to mount the aerial as a square backing onto the centre double glazed window frame. It may have to be spaced off as someone mentioned that there could be metal inside the UPVC.
