19-11-2012, 10:39 PM
Have you got the Bush or Trader sheet?
Set it for the highest voltage. Our electricity is usualiy around 240v, so use the biggest tap.
With a meter across the plug, the reading should be 400 Ohms. (200 on the middle tap.) Give or take.
If you're a coward, remove the cap across the mains.
When you remove a valve (any one, doesn't matter) then the reading should go very much higher, like to Nothing. Make sure the valves are in the right places (new to you and you don't know who's been there before) and then switch on the set and plug and switch on the plug, Keep your hands on the plug switch so that you can cut the power fast if you need to.
The valves should all light and if you're lucky you should hear sound. As in speech or music, not fizzes and bangs.
Cheers,
Steve P,
Cheers,
Steve P,
That signifies a dead - or near dead - short. I think you are getting very close to the cause with the ON / OFF switch.
- and replacement 60-watt light bulbs are a
