Hi All,
Back on the VHF90 (yawn!!).
All wired up, valves in, connected to variac. Start with 25v across the Variac terminals to the switch (off) 25v measured across the mains leads from the switch to the variac. I've turned the radio switch on and then measures 6v at variac terminals and 6v across the switch. Have I got a problem (short) if so, have I wired the switch correctly??
What next?
Regards
Rob
What next?
Regards
Rob
