10-10-2012, 11:15 PM
A few comments on my arrangements for a similar situation may be helpful here.
I have a similar arrangement for an electrical power feed to my outside workshop (which was originally a stand-alone garage: a 1930s style semi-detached house): I installed 3-core armoured cable for that feed. The incoming mains cable (L, N and lead casing for earth) to the house is fed to the house consumer unit and is also fed to an additional small consumer unit that contains an RCD and one MCB: this is connected to the armoured cable that feeds the workshop. The house incoming earth is bonded to the armour of the outgoing cable and that cable also carries a dedicated earth line that feeds the garage. At the workshop end I have another small consumer unit that contains an RCD and 3 MCBs: one for workshop lighting, one for workshop power and one for a feed to the greenhouse (adjacent to the workshop) for lighting only in that greenhouse. The workshop power is configured as a ring-main with conventional 3-pin rectangular sockets, conventionally connected to L, N and E.
The thinking behind having two consumer units (with MCBs and RCDs) was simply that with that arrangement I have effectively provided protection against possible cable faults only between the house and the workshop and also separate protection against faults that occur within the workshop (and green house) itself. All of that was done about twelve years ago, and apart from the occasional 'ker-lunk' from an MCB or an RCD when a mishap has occurred (therefore effectively testing the protection system), I have experienced no problems at all.
I have also installed a low-power emergency lighting system that drops in automatically should the lighting circuit MCB or either RCD trip. Since the workshop has no windows, this is an absolute necessity, especially if the lighting only fails when I am using a power tool!
Al.
Al.
