10-10-2012, 01:32 PM
Hi, I have a caravan in the garden, it is a wooden caravan ie: no metal cladding no metal walls, roof or floor etc.
I need to get power to it, I have dug a trench and laid an armoured cable of a suitable rating at the required depth, the cable has been laid on and covered in pea gravel and has been covered with the proper warning tape (near to surface) It is a three core cable plus the galvanized wire armour shield, the colours of the three cores are Gray, Brown and Black.
The feed is for the caravan only ie: the feed stops at the caravan and does not feed anything else.
Which colours are for L,N & E ?
Can I export the PME/TC-N-S ?
