21-11-2020, 08:18 PM
If you search ebay for this item number 264675809338 this is the small unit I use when doing my development playing! It will do 6.3 at approx 3 amps and 250 Volts at 25mA before it starts to drop output.
I tend to think it a bit safer than using transformers when i have my fingers close to the copper clad work. It will still hurt and discharging a cap charged at 250 Volts is still the same if off mains or not, but it's a feeling.
I do not have a variac unfortunately or a regulated HT power supply, these little units regulate quite well for what they are. I do have a few of them, one powers the time base section I have already build and a second powering this Vision IF, at the end of it all I would switch over to a transformer PSU I built in the early stages of my TT15 audio amp, it will do 250 Volts at approx 80 to 100 mA so that would be the final idea. I do need to change it over to a valve rectifier rather than the silicon diodes I have in there at present.
It will be a few days before the valves turn up, some time to come up with a temp solution.
Adrian
Adrian
Learning as I go!
Youtube EF91 Valve
Youtube EF91 Valve
