Well it keeps me occupied trying to do this and suspect this will keep me occupied for some weeks.
I previously asked a question as to popular/common IF's used in TV, So now with this snippet of knowledge I am trying to build just the vision IF section, using my favourite valve the EF91.
I have a Band 1 & 3 tuner making its way to me, so the idea is to use this and have two EF91's followed by an EB91 (CV140 or CV4007) for the vision detector and if possible AGC, but that can wait.
I have started as I normally do with copper clad board with holes for three valves and also included positions initially for three small screening cans. I use the copper clad rather than try and build an aluminium chassis, being quicker, and cheaper. It also allows my typical dead bug building style where I will solder further small sections of copper clad on one side to act as component islands or HT rails etc. Also being copper clad soldering down to the chassis is not an issue.
Hear is it at present, input coil going to grid of EF91, tuned anode coil and second winding to grid of 2nd EF91, at present output to test set is via a 0.01 uF from the anode, so not matching but gives me an indication. gain presently showing as 26dB, but selectivity is to wide and when trying to add a notch filter for sound it had to much of an effect n resonant frequencies.
The coil formers are these from a Pye Westminster stage, 5mm dia and about 16mm coil space, a bit small for my fingers but managing to wind something on them.
I progress mainly by trial and error, I can not do theoretical designs that include coupling/mutual inductance etc, simple stuff I can get bye, but as I said I think this will be weeks.
Adrian
Adrian
Learning as I go!
Youtube EF91 Valve
Youtube EF91 Valve
