05-04-2017, 12:44 PM
If I was being evil I'd suggest trying it
If you're tempted to do this then use a lamp limiter and see what happens.
On transformers with 2 or more identical secondaries which you might connect in parallel, they should be marked. Often a dot at one end of each winding. So dot to dot, non-dot to non-dot. If they're not marked then connect one of each winding together and an AC voltmeter to the 2 remaining terminals. If the result is 0V, you've got it right and you can make the other connection. If it's double the winding voltage then you've effectively connected the windings in series and you were about to put a short circuit across them untill you realised.
If there's small difference then beware, the 2 windings aren't as similar as you though they were and you'll get a lot of unwanted current flowing in them. This might happen on a transformer with multiple 6.3V heater windings which were intended to powere different sets of valve heaters.
If you're tempted to do this then use a lamp limiter and see what happens.On transformers with 2 or more identical secondaries which you might connect in parallel, they should be marked. Often a dot at one end of each winding. So dot to dot, non-dot to non-dot. If they're not marked then connect one of each winding together and an AC voltmeter to the 2 remaining terminals. If the result is 0V, you've got it right and you can make the other connection. If it's double the winding voltage then you've effectively connected the windings in series and you were about to put a short circuit across them untill you realised.
. It was an educated guess though as I looked up the manufacturer and checked the colours they used on other tx's, but if I had of guessed wrong would it have been REALLY bad or just heated up and a bit of smoke before cutting out the RCD?
