06-10-2016, 10:17 PM
KB 429
08-10-2016, 12:18 PM
Hi Mike,
two rather poor quality pictures of the unrestored KB radio. The mains dropper resistor is positioned at the front of the chassis. Next week I might bring it down from upstairs for servicing. Geordie McBoyne.
10-10-2016, 06:33 AM
I think your KB has to be a 426 David, I don't know of any other radios of that style front except the 427 which is the AC only version and has a shelf added for the power supply.
Very attractive front panel, with beautiful veneers .
11-10-2016, 08:00 PM
The KB is now in the workshop but before a start is made a Brimar 1D5 rectifier valve must be found. The Mazda U4020 is similar so I might borrow one from my Murphy D30. The 1D5 has a 40volt 0.2amp heater. The Mullard CY1C is not a direct replacement because it has a 20 volt heater.
The Brimar 1D5: http://www.radiomuseum.org/tubes/tube_1d5.html Geordie McBoyne.
28-10-2016, 09:23 AM
Unable to find locally a Brimar 1D5 or an equivalent I've bought a Mazda U4020 from an Ebay seller. The U4020 is a near equivalent to the 1D5.
A close up picture of the U4020 reveals that this HT rectifier is in fact a tetrode or pentode connected internally as a diode. Geordie McBoyne.
28-10-2016, 10:15 AM
Hi David
How strange that they should adapt a pentode. I suppose it is the heater volts/current that is the issue. Your Pentode version does not look anything like the one in the valve museum. http://www.r-type.org/exhib/aaa0670.htm The KB service manual lists a 40SUA as an alternative to the 1D5. Mike
Geordie, are you sure that is a picture of a U4020? The valve museum picture is very different: http://www.r-type.org/exhib/aaa0670.htm
Edit - sorry, I should have read Mike's post first. Gus.
28-10-2016, 04:20 PM
(This post was last modified: 28-10-2016, 04:27 PM by Mike Watterson.)
I'm sure I had a U4020 that looked the same as any other rectifier of the period, not a Pentode wired as a diode. No grids in it.
The URC1 is often listed, but you need and extra 20V of dropping somewhere as it's 20V rather than 40V.
31-10-2016, 08:44 PM
The Mazda U4020 arrived today from the Ebay vendor.
I've taking a close up picture of the lower part of the electrode structure. This confirms that this rectifier valve is a diode connected pentode. The links between the grids and anode can clearly be seen. Geordie McBoyne. |
| 7 Guest(s) |
