28-06-2024, 02:51 PM
Drive isn't an issue per-se, it's getting a perfect copy of the pulse width after the opto-coupler.
So, I'm looking at a better opto=coupler than the ILD74 (which is about 3uS rise time) and maybe a pnp Schmitt trigger off 12 V to15 V supply to get a nice sharp pulse that is same duty cycle as original. Meanwhile I have isolated external 0.7 V, 1.4 V 2.1V, as well as isolated adjustable bench 30V and bench 120V PSUs. It's much better than before on internal for 4V to 18V with the IRF510 instead of the original overkill low resistance IRF1401Z part. The idea of an opto-isolated driver is so to automatically vary a fixed external PSU that has + out connected to H+, which is really internal PSU +19V and the Cathode voltage! The GUI has an option for an external PSU, but the original idea of that was that H+ was isolated from onboard PSU and cathode, so that scheme didn't work for direct filamentary cathodes, only insulated heaters. There is even an indirect valves with heater to cathode to save a pin on a B7G base.
My scheme will allow cathode and H+ to be connected anf to PSU+, and the floating FET switch to PSU -ve.
