01-03-2018, 08:41 PM
Since I made this up I have made some changes.
The triode AF amp has been replaced with a Pentode 1Ж18Б. The original only gave marginal gain and on low level sources didn't give enough audio.
The HT for the 1Ж18Б is derived from a small inverter that gives 70v, the anode is fed via a 100k and the G2 via a 2.2m resistor. Bias is derived as in the last circuit.
I cannibalised a strange Christmas light that is some sort of plasma device and I use the inverter to feed the RF amp and input audio amp. So far it works perfectly.
My plan is to rebuild this and move away from the laminate sheet and finalise it properly.
I have proved it's reliability as excellent so time to tidy it up and sign it off as comlete.
