05-12-2016, 07:52 PM
(This post was last modified: 05-12-2016, 07:53 PM by Murphyv310.)
Hi.
I quite like trying different approaches to making micro transmitters for Medium Wave and feeding the signal round the shed.
I recently bought some dual control grid Russian Rod valves 1Ж42А.
Today I had a little experiment to see if it would work as a micro transmitter using one control grid for HF oscillation and the other to modulate the valve with AF.
I eventually got the valve to oscillate reliably strapping a crystal directly between G2 and the first G1, G2 was fed from HT (9v) via an RF choke, G3 is grounded and the second G1 is fed audio via a 0.047uf cap and returned to ground via a 680k
The Anode is again fed from 9v via another RF choke. The output is a very clean sine wave around 5v p-p. Using a couple of meters of wire from the anode you can feed the shed quite happily, the signal dies before reaching the house just under 10 meters away.
I improved the range to about 25 metres by making up a tank circuit.
Audio quality is OK, not hi-fi but still good, modulation is only good up to 50% but some changes could improve this, above 50% distortion creeps in.
The circuit will just work at 3v HT and anything between 4.5v & 9v it works fine above 9v the RF drops and performance is less.
With so few components it has to be one of the simplest I've made.
