11-09-2015, 08:25 AM
(This post was last modified: 11-09-2015, 08:36 AM by Old Sparky.)
The 108 was disconnected from the supply when I did my resistance checks, and the 'aux-in' connection is, as I always do them, connected via the 'radio/aux' switch directly to the top of the v/c, so, unless there was a mod. made to the 108 I have that makes it differ from the published circuit, not unknown of course, then I'm at a loss to know why I don't measure a DC resistance to chassis at this point. I'll try and post a higher resolution drawing at some point, but I did get a 'file size is too large' message when I first attempted to post that circuit diagram. Incidentally, with regard to your earlier suggestions, Mark, I've never put shunt resistors on 'aux inputs, since the radio's volume control forms a DC load.
Admittedly this can be anything from 5k to 100 or 220k in different radios, so perhaps a low value resitor is desirable.
