10-09-2015, 08:05 AM
As far as I know, this is straightforward. I've just made up an adaptor to allow an I-Pod or other device to be used with a Radiomobile 108SR car stereo 8 Track player. Although this unit is stereo, it includes an AM radio, which is obviously mono, coupled to the o/p stages via series resistors. I know that, when fitting such an adaptor to a mono radio, series resistors of between 1 & 10k are needed in each channel, but haven't fitted them in this case. Preliminary tests with an AF Generator indicate that this will be OK so I'll probably leave it that way, unless anyone thinks that resistors should be added.
