(23-12-2015, 11:23 AM)Brianc Wrote: That's a really fantastic set, Lawrence and I can appreciate the efforts which are going into your reverse engineering! It is the sort of receiver used in embassies the world over in the 1920s. I note that in the RF stages, the range switching is so arranged that there is never a shorted winding damping the others unlike the simple LW-SW switching of that era.
It reminds me of an ST&C Supersonic Heterodyne type 44004 from 1926 which I have. The set was specifically intended for FO type duties and was available with or without cabinet. I will upload the details to Radiomuseum in the near future as they have now corrected their entry for the Western Electric version of the set, the 4004, which was listed as a 44004. I have the curved labels which are positioned above each of the controls - but I can't find them at the moment. The hole in the panel is for a two range meter which measures the two HT+ feeds. The valve are mostly WECO triodes in series/parallel on 4V LT.
Brian, my apologies for not replying in detail to your above post earlier, the reason was that what you suggested in it reflected a hunch I had with this receiver, I had a hunch it was something official to do with a government/ military.
The first task for me was to try and establish what this unit was first of all, that's why the decision to reverse engineer the circuit was taken.
The conclusion of that was that it is radio receiver for sure and an unusual one at that.
Having done the above the next task was to give the cabinet a close examination for any clues, the cabinet has badly deteriorated in places, however I wanted to establish if the cabinet was original to the receiver or the cabinet was a later addition eg: a cut down /modified bread bin done by a home DIY'er, the cabinet is roll top of the type that would be found on a writing desk or bread bin.
I've finished examining the cabinet, with an interesting result.
The cabinet itself and the roller shutter is constructed from mahogany or a very similar type of hardwood, the backing cloth for the slats has long since detached, all the cloth is still there but generally rotten, it looks like calico.
The cabinet base has molded edges as does the cabinet top, the slats slide in a rebate, pinned to the inside edge of the rebate near the rear edge of the cabinet are three leaves of thin varnished veneer, the three leaves have not been glued together and are fixed inside the rebate close to their edges by some thin pins, the bottom of the leaves sit flush on the cabinet base, the tops of the leaves finish just below the end of the radius of the rebates near the back edges of the cabinet sides, the leave that's nearest the cabinet back is chamfered along its top edge in favour of the slats, the jointing method for the cabinet base and sides is by butt joints, pins and glue, however the top is screwed on using eight screws.
When the receiver is in the cabinet there is plenty of clearance between the back of the receiver and the three leaves of thin veneer, access to the gaps between the veneer leaves can be gained by unscrewing the top and removing it.
That suggests to me at the moment that the gaps were there to store a document or two in, a secret compartment maybe, I might be wrong on this and just dreaming so what I'll do is take some photo's and upload to the forum so folks can see what's what and offer their views.
The cabinet is an exact fit to the receiver, I don't think it's a DIY home brew job, There's no evidence of the cabinet sides and the ends of the slats being hacked with a hand saw by a DIY'er, the backing cloth for the slats finishes approx 6 mm from either end of the slats as one would expect, that glue line is visible because the cloth has long since become detached, the glue line does not extend beyond the edges of the cloth.
I have made some more observations about the bias battery connections and another connection but I'll leave that for another post, I also made a mistake reading the value of the filament rheostat, it's 8 ohms not 6 ohms as I first concluded,
The cabinet pictures will be uploaded today, Mrs has bought me a Petzl
....ideal for this type of work.Lawrence.
