15-02-2021, 03:13 PM
Hi.
Chocolate block is rarely a good idea on mains especially if the load is high.
The continual heating and cooling can lead to the screws loosening off for no apparent reason. Then the connection begins to go high resistance and could of course start a fire.
I've seen crimps in the past that have been also soldered and heat shrink insulation fitted, they have been OK on dismantling TBH.
I always go round again and retighten. If you remember the old fashioned Wylex fuse boxes they had twin screws for each L and N conductor. All modern CUs just have a single screw. I reckon this was the cause of many fires and the reason for the amendment to the wiring regs to enforce metalclad CUs.
