02-09-2026, 10:53 AM
I am embarking on a radio restoration of the above set but wondered what the differenced were between the U319 and the U319A?
Regards Nick
Regards Nick
Ecko U319
Regards Nick
02-09-2026, 12:03 PM
Trader 1416 covers the U319. Fairly standard live chassis design. Trader sheet available here: https://elektrotanya.com/ekco_u319_am-fm...nload.html
I can't find service data for the U319A. https://www.radiomuseum.org/r/ekco_u319a.html It's easy to find other people's accounts of doing work on a U319.
02-09-2026, 01:06 PM
Jeff, thank you - I do have the 'trader' printout 1416 which covers the U319, however, as you say there does not seem to be any info on the U319A - this later model could be a colour edition - I understand that at some point Ecko produced a bright red edition in order to keep up with fashion trends! so it could as simple as a colour change, It is likely I will be getting an example of both models - to make one good radio from the two - so if I can see any differences between them I will post these on here.
Regards Nick
02-09-2026, 03:21 PM
It's quite a decent set (it's Ekco by the way, not Ecko - common mistake!).
The relatively large cabinet does mean the dropper resistor runs cool, and the sound quality is helped by the large cabinet. I do find on VHF that the tuning drifts over the first 10 minutes though.
03-09-2026, 11:21 AM
(This post was last modified: 03-09-2026, 11:25 AM by Mike Watterson.)
The "A" version seems to use a ribbon/twin feed for the connection to rear panel built in aerial instead of a single wire.
Likely some other minor changes. I have an earlier wooden Ekco set in the attic using a DM70 magic eye with filament powered from O/P valve cathode. Edit This one https://www.radiomuseum.org/r/ekco_u243_u_243.html Likely one of the first Ekco models with FM. Likely very similar to the U319/U319A. |
| 2 Guest(s) |
