26-08-2026, 09:23 AM
I thought members would be interested in some bench test equipment I made up last year,
I picked up a bare 6Amp variac at a radio rally and made up this enclosure - the steel cabinets are from TLC Electrical wholesalers and are around £30 - well made and perfect for these types of project.
The isolation transformer - using 1:1 toroidal transformer, for powering up unknown repair items safely, when I first built this I had a few problems with the transformer tripping my consumer unit - these toroidal transformers do create quite a surge on start up so I fitted a BC socket inside the enclosure with a 40watt incandescent lamp which I can switch in series with the mains incoming for first switch on, it absorbs the surge, I then throw the switch and this shorts out the lamp ready for use. (it works well as long as I remember to set the switch!)
Also built a current absorption device - lightbulb! this is useful for test items that may be short-circuited.
I recently acquired an AVO RF135 Audio/radio frequency signal generator for a recent FM Radio repair and set up, but prob wont ever use it again as I have a Gould AF sig gen for general use. this is available for sale if someone can make use of it.
