20-08-2025, 08:37 PM
It was the FARS rally meeting at Sandtoft on Sunday, I look forward to it, there is usually a good selection of interesting electronic gear goar on sale there. This time was no exception and I came back with HP and Tektronics 100 MHz scopes, a video vector analyzer and waveform monitor and also this old piece of test equipment. As far as I can tell it is for testing three phase watt hour meters, made by an early player if this field - Chamberlin and Hookham of Birmingham. It caught my attention as it seems to have a three phase transformer in it which I thought could be useful or interesting. I've not found anything like it by searching online. I'm tempted to try and get hold of an old watt-hour meter to see if I can exercise it before abandoning it into a cornet of my shed but if anybody knows anything about these I would like to hear about it.
My other acquisitions are more interesting, I have a Tektronix 2236 'scope. This one has a built in DVM VFD display to measure input waveform properties and also conventional 4mm jack inputs to use it as a traditional DVM. A precursor to modern scopes with everything displayed on the screen. its mainly working now, I'm waiting for some replacement transistors to fix the vertical display. The HP scope is a 1740A, I cant get the timebase to trigger so a bit more manual reading needed to identify where the problem could lie. The vectorscope and monitor are working, Ive tested them on my colour bar generator - a RIFA cap inside gave up during this test put it hasn't caused any further damage - I'm glad I tested it in the shed though because it smelt awful.
Best regards, David.
