08-08-2025, 04:47 PM
I've just been given a Bush SRP31D which should end up in one of the period living rooms we're planning at the Broadcast Engineering Museum. The non-technical donor said it wasn't working and it doesn't need to work but I'm curious.
The SRP31 data is in R&TVS 1959-60. A pair of ECL83 pentodes in push-pull with the triodes acting as pre-amp and phase splitter. A note in R&TVS 1961-62 says the SRP31C adds a facility to connect and external amp for stereo which I can also see on my SRP31D. The Radiomuseum site says that the SRP31D uses a pair of ECL86. I can't see the SRP31D data in R&TVS or Trader but guess that the circuit is very similar but beefed up for the extra power. I hope that the ECL86s are OK as they're a bit scarce and expensive these days. The get-out is a pair of PCL86 (I have several NOS) and a small heater transformer.
Does this model have an electrostatic tweeter which I guess is unlikely to work any more?
I haven't touched a gram like this in many years so any helpful hints please. The amp looks easy enough. Bring it up on a lamp limiter and change the coupling caps to the output stage regardless. Buzz test at the input.
