08-02-2025, 11:13 AM
(This post was last modified: 08-02-2025, 11:16 AM by ppppenguin.)
Do rectifiers in parallel share nicely? These three bridges didn't. They are from the Phlips PM5544 electronic testcard at the Broadcast Engineering Museum. The symptom was massive hum on the picture. See photo from 'scope. It was actually the main +5V rail feeding all the TTL that was in trouble. Exactly how all the logic kept working we don't understand. For strange reasons known only to the Philips designers they decided to use three bridges in parallel to provide about 3A for the logic. They were also mounted tight up against each other. Now replaced by a single chunky bridge bolted to the back panel.
It's not the first time that the PSU in this unit has fried. These rectifiers were actually RS branded replacements. These repairs must have been done when it was in use at BBC Pebble Mill. The bridge bolted to the back panel that's in one of the photos had probably been fitted at the same time. It supplies one of the analogue power rails.
I don't think much of the way the BBC fitted their favourite XLR-LNE mains inlet either.
By chance I've also been fixing a Philips LDK4210 SPG recently. The mains transformer had overheated and had shorted turns. A similar bridge had an open circuit diode. Halfwave rectification puts DC though the winding and saturates the transformer. The problem is that if there's enough margin and/or the mains voltage is high enough the unit carries on working despite the rectifier being halfwave.
