10-10-2024, 11:39 PM
Hi,
I have just acquired a Columbia 229B 78 rpm turntable and looking for some advice and help in restoring it to working order.
Inside the base, I found a large grommet that has obviously come off something. Does anyone have any idea where it is supposed to be?
The motor makes a buzzing noise and the auto stop mechanism appears to be worn away and doesn't work but that's not a problem at the moment. I guess the buzzing might be due to a lack of oil in the bearings and also the suspension rubber bushes gone hard.
The coil in the pickup head seems to be intact but I'm puzzling over a little tag board that is providing a junction point for the pickup wiring from the head and the outgoing signal cable. The tagboard also carries a couple of resistors but what is the purpose of these?
Underneath the turntable there is a screw and washer that appears to connect these resistors but can some somebody tell me what they are used for?
I have seen it mentioned that the rubber suspension in the pickup head goes hard causing a very low output.
How does the pick up head come apart. There are some hard bits of filler that could hide screw heads. Do I just dig these out?
Having got it apart, what is best type of rubber to use to replace the old hard pieces.
Does anyone know if there is any official service data or any help and hints from the very experienced members on here would be most welcome.
Cheers.
Cheers.
