16-06-2011, 05:53 PM
I use Photoshop Elements 4 intended for photo editing - an aging program, of which I'm only capable of using the basic functions, but find it useful for cleaning up dial scans and such like. I also use it for modifying and helping create PCB artwork at a very basic level. I'm in the final stages of my restoration of a Stella 105U, which has been awaiting attention since Nov 2010 Golborne Swapmeet, and one of the things I wanted to do was to clean up and reprint a shabby paper label stuck to the inside of the cabinet, which shows the valve positions.
I don't possess the sklls to create a new label, which - to anyone who does have such skills - will I'm sure be a quick and easy task. Hence, I scanned the old label into Photoshop and set about cleaning it up using the eraser, brush and fill tools. I've attached a couple of pics of the before and after results, which might be of interest to anyone wishing to clean up dial scans and the like. It's a time consuming task, which takes several hours, because to do it properly it's necessary to enlarge the scan so that you can, if need be, edit single pixcels, then save the cleaned up scan in whatever size you wish it to be.
Really, it's dials where this sort of software comes into its own because without a dial, a radio is all but a write-off even if the chassis works well and the cabinet is in good condition. The serious limiting factor with creating dials, which I've mentioned before, is that we can't print white on a conventional ink-jet printer when making water-slide transfers (decals as the Americans call them).
Old and new labels below.
Hope it's of interest.
David
David
