02-06-2024, 03:21 PM
(This post was last modified: 02-06-2024, 03:21 PM by Mike Watterson.)
The simplest idea is an FET shunt regulator on a heatsink in a perforated insulated box, Maybe with a 12V fan.
The series ballast will use tungsten lamps. The only universally available kind are 26W for ovens, thus rated for up to 360 °C. There may be some old stock regular halogen lamps, or 60W red ones for fireglow effect where the heat makes a disk spin. I do have some 28W halogen cooker hood lamps.
The best way to test really high power valves is in the actual equipment, so I will go with 26W screw in oven lamps.
The most available HT transformer is the 110-120/220-240 isolated shaver outlets. These have a usually a shunt to limit power to under 20W and have good isolation. There is usually a themistor which can be removed. Obviously people can source other transformers or use two transformers back-to-back.
Two cheap FETs used in 500W SMPSUs can be used. They are 1nF to 5nF gate capacitance, but a 10K in series close to the gate is a good idea. A separate +9V (approx, I'll check) supply via a 100K pot will set gate bias to vary shunt current and thus HT after the series lamp(s).
Likely a number of 26W lamps are used in series, or possibly parallel, depending on selection of 150V, 300V or 600V ranges and load. Ideally to test valves you have two duplicate HT circuits.
The 1N4007s will give a nominal +160, +320 and +640V HT with no load. Feeds via 1M, 2M and 4M approx can be used for leakage tests. It can also give a nominal -160. A reversed 1N4148 can regulate to about -110V to -120V assuming a series resistor for under 200uA. A load of a 2M2 Ohm pot is less than 60uA. Perhaps a 1M or even 470K pot is feasible.
The supply for fan and FET bias can be a 9V or 12V transformer, giving between -12V or -24V for grid bias (9V) or about -16 or -32V (12V AC). So zeners for 9.1, and 22V or 12V and 28V could be added.
The 470K to 2M pot(s) can be thus switched to 3 different negative supplies.
Cheap DMMs or panel meters used to display the manually adjusted voltages, and optionally (ideally also) load currents.
There is no explicit HT regulation. Just measure it and adjust the FET bias knob. The negative supply could have the pot calibrated for situations where no or little grid current flows.
Next I will lash up a "breadboard" (a case where a literal one may suit) as I have a good few lamps, FETs, pots, caps, rectifiers, zeners, diodes etc. I'd not trust heatsink insulators at these voltages so the entire of the pair of heatsinks will be live. I've loads of suitable ones off PII style CPUs. Only up to 20W needing cooled, as worst case is HT max / 2 and no external load.
