06-03-2024, 10:22 PM
(This post was last modified: 06-03-2024, 10:23 PM by Geordie McBoyne.)
I'm servicing a Philco A527 Peoples set. This is the "de luxe" version of the model 444.
The circuit consists of a four + one superhet receiver for long and medium wavebands.
valve line-up is: 6A7 frequency changer, 78E IF amplifier, 85 or 75 double-diode-triode and type 42 output. Type 80 HT rectifier.
The set works but the audio amplifier was not delivering much output. Replacing the 75 DDT improved matters considerably.
The circuit diagram indicates the double-diode-triode to be a type 85. It's possible the diagram is for "run one" receivers. The set I'm servicing had a Philco 75.
So now we more audio power but when the volume control is advanced to maximum the audio becomes distorted. This was found to be negative going DC component biasing the amplifier to near cut-off. The volume control also functions as the second detector load resistor. The solution is to insert a 0.005uF capacitor between the volume control slider and the control grid of the triode. For grid current biasing connect a 10Megohm resistor between the grid and chassis. Change the triode's anode load resistor from 47Kohms to 270Kohms.
The IF transformers peak-up OK but the signal generator will be connected up to confirm that the IF is 451Kc/s.
The A527 is at the left side of the picture. The other Philco receiver is a model 333 which has a chassis from a model 296, the wood cabinet version of the 444.
Geordie McBoyne.
Geordie McBoyne.
